Heads/cam upgrades for 1983 LG4
Old Sep 6, 2018 | 09:34 PM
'83Daytona's Avatar
Car: 1983 Pontiac Trans Am
Engine: 305 CI V8(LG4)
Transmission: T5 5-speed
Hello all,
I currently have the LG4 305 for my trans am on a stand torn down to the short block (only crank and pistons are in it at this point). I am fairly set on replacing the stock heads with World S/R Torquer 305 heads because I like the larger ports, bigger valves and smaller 58 cc combustion chamber... I'm just torn as to which cam to buy for it... I live in California as well so I've been pushing it as much as I can within emissions regulations, but I've been thinking about the summit k1103 cam... it sounds like the best bang for the buck for a 305 inch motor, and waaaaay better than the teeny weeny cam I pulled out. I am on a budget and this sounds promising, yet if there are any drawbacks/better suggestions, let me know!
Thanks to anyone who shares their knowledge!
-Zack
Old Sep 7, 2018 | 07:10 PM
NoEmissions84TA's Avatar
Re: Heads/cam upgrades for 1983 LG4
Crane (used to be called) CompuCam 2040 would be the largest to work with what you have and still pass emissions.
https://www.summitracing.com/parts/crn-114132
Here is a similar build you can use for reference:
https://www.thirdgen.org/forums/tech...-aerohead.html
https://www.thirdgen.org/forums/auto...onversion.html
https://www.thirdgen.org/forums/tech...appet-cam.html
Josh R
Jun 6, 2009 02:43 PM
Josh R
17
Mar 29, 2009 06:26 PM
327_TPI_77_Maro
Carburetors
Feb 27, 2006 09:12 AM
