ventilating small cap dizzys...
Old Sep 14, 2018 | 09:08 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
every small cap distributor I have has had bad rust/corrosion of the pickup coil and reluctor because of ozone buildup while not a single "large cap"HEI of mine has ever had even a trace of this problem-so going to ventilate my "small caps"beyond just the two screened holes on the bottom:Thinking about adding a hole in cap with a vent pipe to air cleaner snorkel or air intake on back of alternator to keep ozone out.1992-93 "Optispark"dizzys had ozone damage problems including failed ball bearings,but 1994-up were ventilated.
Old Sep 14, 2018 | 09:32 PM
NoEmissions84TA's Avatar
Re: ventilating small cap dizzys...
You could try connecting to manifold vacuum with a very small diameter restriction (like .030" or less) in that line.
Old Sep 15, 2018 | 08:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Or just route a hose to the intake duct work (like LTIs did) so you don't have a vac leak.
2bfeard
Feb 8, 2009 06:13 PM
CamarosRUS
Nov 1, 2008 11:07 PM
jayk2k3
Aug 20, 2008 07:55 PM
Cannon007
Dec 24, 2007 06:24 PM
