92 Camaro
92 Camaro
Hello I just bought a 92 Camaro 305 tbi I’m not good with cars but my car keeps overheating I’ve changed the coolent radiator houses thermistat and clean the reservoir can you guys help me
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 Camaro
Start with looking to see if the fan works. With the key on you can ground the wire going to the cylinder temp switch. This switch is in the passengers side cylinder between cylinder number 6&8. If that doesn’t kick on the fan you need to look at the relay. Sorry I don’t have the schematic for it.
Engine: Lb9
Transmission: M20
Re: 92 Camaro
The coolant fan switch is cut off in the picture but is tied into the ac pressure switch.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Shepp84Z28
Apr 8, 2019 10:36 AM
