Cam degreeing double check
Old Nov 14, 2018 | 09:08 AM
HINKSON AUTO's Avatar
Tip of the day. When ever degreeing a cam in and you're second guessing yourself. The best way to double check is to put # 1 piston at TDC in over lap and put both lifters in for #1 cylinder, If the cam has 4 degrees advance built into it and you put a straight edge across the 2 lifters and the intake lifter is .020 to .035 higher then the exhaust lifter your fine. If the cam has no advance ground in both lifter should be appox. the same height. If the cam is retarded the exhaust lifter will be higher then the intake lifter. Before degree wheels and indicators were around this use to be the old fashion way of checking to see where the cam was installed. Learned this many years ago from an old timer. This does apply to BB's its a little more complex as the lifter do not run inline with each other. You have to use 2 indicators or record the two heights in over lap and compare.
Old Nov 14, 2018 | 01:01 PM
GeneralDisorder's Avatar
Re: Cam degreeing double check
Thanks! I'm definitely going to use that. Makes sense although I imagine the exact height difference depends on the cam grind? How does a split duration grind affect it? Would that potentially invalidate the test? I guess I'm asking what types of cams would this potentially be a bad idea to use this method on?
GD
Old Nov 14, 2018 | 01:08 PM
GD
So far it has worked on every cam I have ever de-greed in.Marine you name, Harold Brookshire that use to own Ultadyne cams taught me this method of checking to see if you in the right direction.
AlkyIROC
Aug 7, 2002 10:09 AM
lexussc94
Nov 2, 2001 06:48 AM
2QUIK6
Aug 8, 2001 08:46 PM
87Z-ya
Feb 23, 2001 09:17 PM
Beefy89
Sep 27, 2000 08:40 PM
