Cam Degreeing
Old Sep 27, 2000 | 12:00 PM
Beefy89's Avatar
Cam Degreeing
Recently I rebuilt my L98,and installed an LT1 cam,but I didn't degree it to figure out the the event timing.I also installed a Cloyes double true roller chain with the Hex adjust,and set it at zero.Anyone set theirs differently?
We need Perry Mason
Old Sep 27, 2000 | 07:39 PM
md's Avatar
md
I always degree the cam. You'ld be amazed at how far off the cam will be by just using the timing marks. I've seen them up to 2* off. That's why I always degree them in anymore.
I just installed a hex-adjust like yours. It didn't have a mark on the cam gear. I got it as close as I could with #1 at tdc and using the dial on the intake lobe. I got it dialed in, but the hex mark is in the 2nd mark and not straight up. I'll adv/ret the cam as the dyno pulls dictate. By playing with the hex bushing and watching the wheel, one dot moved the cam roughly 2*.
Mike
Old Sep 27, 2000 | 08:35 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
I had my L98 rebuilt too and thought about having my mechanic installing the cam a degree or two advanced. Advancing it effectively changes the specs ground in the cam. In the end I decided to have him install it straight up and am happy with it.
Old Sep 27, 2000 | 08:40 PM
87kevroc's Avatar
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
masonta
Sep 1, 2015 06:40 PM
