Engine now running, but gauges not right.
Old Nov 23, 2018 | 04:20 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Hey guys, after 4 years of not driving my 85, it's now back up and running. I did a full engine build and all, but my problem now is the coolant temp garage shows 280, which I have checked, and the engine seems to be running...well.. not that hot. Also my oil pressure garage isnt reading Any at all. Do you guys think this could be a cluster, sensor, or other issue?
Old Nov 23, 2018 | 05:42 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Engine now running, but gauges not right.
More than likely a grounding issue. One ground from the back of the head to the firewall, then there are ground connections under the dash, then check the cluster plug under the dash. check and clean all ground connections.
GoldenRhino
Aug 10, 2019 01:47 PM
firstfirebird
Aug 29, 2008 06:57 PM
koll
Apr 26, 2006 06:37 PM
foff667
May 2, 2001 08:53 PM
