Power Steering Bracket Removal
Old Nov 24, 2018 | 11:44 AM
DMack_VB757's Avatar
Car: 92 Firebird
Engine: 305 V8 (L03)
I'm trying to remove the power steering bracket so I can get to the water pump. I'm having trouble getting access to bolt #18. I need to get a torx bit where the pencil is pointing. The knuckle on my torx bit ratchet attachment is interfering with the fill cap. The tool stores do not seem to have a long & skinny torx bit, stuck with the short ratchet pieces it would seem. Is there a special tool for this or do I try something else? See bolt #18 in the diagram.
92 Firebird
305 V8
Old Nov 24, 2018 | 11:49 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Power Steering Bracket Removal
I don't see why you have to remove the power steering bracket to remove the water pump. I have removed the water pump from my cars a few times and never had to remove the power steering bracket. If you don't have the tool, see if Autozone or whatever parts store near you has it so you can rent it.
Syncity05
Jul 29, 2015 08:02 PM
MaxxMitchell
Exterior Parts for Sale
Jan 15, 2010 07:34 AM
Eighty5TransAm
Aug 21, 2001 12:08 AM
1989CamaroRs
May 2, 2001 08:46 PM
