Valve locks
Old Nov 28, 2018 | 03:20 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Valve locks
Need help with part number for direct replacement valve locks for 1990 corvette 113 heads. Search brings up multiple answers 7° and 10° as well as recess for valve caps. Just need direct replacement as mentioned.
Old Nov 28, 2018 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Valve locks
I don't think OEM ever used 10* locks. Stock retainers normally use 7* locks. You can also gets locks to add spring height. Locks are also for different diameter valves and depends if the groove in the valve is square run or round.
Old Nov 28, 2018 | 11:35 PM
DiabloWS6's Avatar
Re: Valve locks
ok I was about to purchase the 10° valve locks. It's the most common search results...but thanks that helps a lot.
manolis1969
Aug 7, 2013 11:22 AM
david auster
Aftermarket Product Review
Apr 7, 2001 10:09 PM
NORT
Feb 17, 2001 08:53 AM
Jester
Jan 16, 2001 07:52 PM
