1991 GTA, code 53
Car: Trans Am GTA
1991 GTA, code 53
Hope ssomeone can help, having issues with a 91 Trans Am GTA, while driving the ses light comes on, engine runs rough but if I keep revs up it will clear itself the ses goes out and runs normally, if I let revs drop the engine will stall. Engine will restart immediately with no ses and runs normally again, can go for 500-1000 miles before reoccurring. On the rare occasions ses stays on shows code 53. Once the ses light goes off no codes are stored.
Car: Trans Am GTA
Re: 1991 GTA, code 53
New battery and alternator fitted when problem first occurred, I have had system tested recently, all operating perfectly. At the moment it is just a 20-30 second inconvenience every few hundred miles, but would like to fix problem.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
My first thought was bad voltage regulator in the alternator.
the code 53 will throw is a high voltage is seen at the ecm for more than 2 seconds.
I wonder if a bad ecm could cause this problem. Since it’s intermittent I don’t know where else to tell you to start.
Car: Trans Am GTA
Me too, that's why I changed battery and alternator, next thought was ECM, unfortunately they're not that easy to get over here.
Engine: Lb9
Transmission: M20
You should look at RockAuto.com they do international shipping .
Engine: Lb9
Transmission: M20
Here is a application list for your 1227730 ecm assuming you have tpi.
https://www.thirdgen.org/ecminterchange/
Car: Trans Am GTA
Thanks, never thought to look at rockauto, usually the first place I go for parts, not as expensive as I thought, even with core charge.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
im not sure, I do know the code 53 shows when 17 volts or higher is seen at the ecm. I’m assuming it’s on the constant power of the ecm not the switched ignition.
Car: Trans Am GTA
Now you got me thinking, could it be as simple as a bad connection seeing as it is so intermittent and fault only lasts for a few seconds.
Matthew Thayer
Aug 25, 2012 08:16 PM
