Engine sizes and emissions
Old Jan 8, 2002 | 07:53 PM
phineas's Avatar
Living in Maryland forces me to at least try and maintain an emissions compliant car. I realize there's a lot of mods that can be done without adversely affecting the emissions output of the vehicle. Assuming everything is in good working order, what types of mods really affect the emissions levels a vehicle is putting out ? For instance, would increasing the displacement (as long as it's within the limits of the intake/exhaust systems capacities) necessarily cause anything to go amuck ? I'm just looking for some generalized guidelines on things that stretch a car's abilities to reduce emissions. Thanks!
Kyle
Old Jan 8, 2002 | 08:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
displacement increases don't neceassarly cause failures
but, to make the engine run right (even at idle), you have to provide more fuel, that in an of itself will require cause increases of emission. Other changes that factor in are increased compression (raises NOX readings), advanced timing (same thing) and longer cam durations (CO readings).
Increasing the capability of the engine to flow more air (by using headers and some headwork) can often pass testing without problems.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
