1992 Camaro RS - Active Recalls
Old Mar 7, 2019 | 12:25 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
______________________________________________________________________________________________________________________________________________
RECALL Subject : FUEL:FUEL TANK ASSEMBLY:PIPE:FILLER:NECK , 1 INVESTIGATION(S)
Report Receipt Date: APR 25, 1994
NHTSA Campaign Number: 94V077000
Component(s): FUEL SYSTEM, GASOLINE
All Products Associated with this Recall
Details
1 Associated Document
Manufacturer: GENERAL MOTORS CORP.
SUMMARY:
THE FUEL FILLER NECK SOLDER JOINT CAN DEVELOP CRACKS OR PIN HOLE LEAKS, WHICH DOES NOT COMPLY WITH FMVSS NO. 301, "FUEL SYSTEM INTEGRITY." THE CRACKS AND HOLES CAN ALLOW FUEL VAPOR AND FUEL LEAKAGE.
CONSEQUENCE:
CONSEQUENCE OF NON-COMPLIANCE: GASOLINE VAPORS AND FUEL LEAKS CAN RESULT IN A FIRE IF EXPOSED TO A SOURCE OF IGNITION.
REMEDY:
DEALERS WILL INSPECT THE FUEL TANK ASSEMBLY AND REPLACE THOSE WHICH EXHIBIT THE CRACKS OR PIN HOLE LEAKS.
NOTES:
SYSTEM: FUEL; FUEL TANK ASSEMBLY; PIPE; FILLER; NECK; FMVSS 301. VEHICLE DESCRIPTION: PASSENGER VEHICLES. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED WITHIN A REASONABLE AMOUNT OF TIME OR THE REMEDY DOES NOT CORRECT THE NONCOMPLIANCE, PLEASE CONTACT CHEVROLET AT1-800-222-1020 OR PONTIAC AT 1-800-762-2737. ALSO, CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
RECALL Subject : POWER TRAIN:TRANSMISSION:AUTOMATIC
Report Receipt Date: OCT 23, 1992
NHTSA Campaign Number: 92V154000
Component(s): POWER TRAIN
Details
SUMMARY:
THE AUTOMATIC TRANSMISSION SHIFT CONTROL CABLE CAN SEPARATE.
CONSEQUENCE:
SEPARATION OF THE TRANSMISSION SHIFT CABLE CAN PREVENTTHE TRANSMISSION FROM BEING SHIFTED INTO THE PROPER POSITION. THIS CONDITION CANCAUSE UNEXPECTED VEHICLE MOVEMENT WHEN THE TRANSIMISSION INDICATOR IS IN PARK ORNEUTRAL POSITION AND THE TRANSMISSION IS IN A DRIVE MODE; THIS COULD RESULT INA VEHICLE CRASH WITHOUT PRIOR WARNING.
REMEDY:
THE DEALER WILL REPLACE THE SHIFT CABLE.
NOTES:
SYSTEM: TRANSMISSION.VEHICLE DESCRIPTION: PASSENGER CARS WITH AUTOMATIC TRANSMISSIONS.
https://www-odi.nhtsa.dot.gov/owners....prod_ids=1500
Marlyn
Sep 12, 2003 04:47 PM
Paul_Hughes_87 T/A
50
Jan 25, 2002 03:30 PM
Mikes86SC
Feb 21, 2001 11:40 PM
Demon Z28
Feb 18, 2001 03:56 PM
