RPMs high; No sounds or change in engine
Old May 7, 2019 | 01:57 PM
robthomas16's Avatar
I have a 92 camaro with a 305.
It was sitting for awhile, and after I started it up, its RPMs are high, but the engine isn't making any noise or sound that isn't normal.
What could be the problem? Is it the engine?
Old May 7, 2019 | 02:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: RPMs high; No sounds or change in engine
Originally Posted by robthomas16
....It was sitting for awhile, and after I started it up, its RPMs are high, but the engine isn't making any noise or sound that isn't normal........What could be the problem? Is it the engine?.....
Of course it's not the engine , it's the classic tach failure that most of these cars eventually experience . If your engine was truly revving at close to 4K RPM in park you'd damn well know it .
Do a search of "tach reads high" here and you'll find lots of threads about it , and even threads discussing how to replace the failed component in the tach that's causing the falsly high reading .
Old May 7, 2019 | 02:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tran...ds-double.html
Orr89RocZ
Aug 1, 2006 09:37 PM
80smetalfan
Mar 21, 2006 05:01 PM
brodyscamaro
Oct 25, 2002 08:52 AM
Beast5spdGTA
Oct 6, 2000 12:17 PM
