Narrow body rocker arms
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Does anyone know if either of these rocker arms will fit(without modifying the valve cover) under a stock height center bolt valve cover on a small block Chevy engine? Trick Flow TFS-31400513 or Scorpion 1038. The cylinder head I'll be using is Trick Flow TFS-30310006. I read it requires a narrow body rocker arm with the 1.470" diameter valve springs these are equipped with. I already performed a search and didn't find the answer to my specific question/application.
Car: 88 Camaro SC
Re: Narrow body rocker arms
Or, how about Crane 10759? Anyone use these under stock height center bolt valve covers?
Engine: 4++,350 & 305 CIs
I have narrow body crane rockers on 113 heads under stock covers. If the heads have the same valve spacing as stock heads, no reason they shouldn't fit.
Car: 88 Camaro SC
I'll be using the Trick Flow TFS-30310006. Valves are 1.94" and 1.5". I'm not sure on the valve spacing though. Sounds like some research is in order regarding valve spacing on the Trick Flows. See if I can come up with anything. Thanks for the response.
I'm 99.9% you'd be ok with that head. I ran normal fat comp stainless rockers on my old twisted wedge heads (with the goofy valve angles). Not sure what you're going for but if it's for a 350 and up, I'd look for a head in the 195-200 cc range.
1983Zsled
Aftermarket Product Review
Oct 11, 2013 01:09 PM
TPIMonteLS
May 31, 2003 07:27 PM
FormulaGod
Dec 7, 2000 02:43 PM
