I have a 1988 engine w/centerblot heads, do i need narrow body rockers?
Old Dec 7, 2000 | 12:00 AM
FormulaGod's Avatar
I have centerbolt valve covers and wanna get roller rockers. I need narrow bodies, right?
Crane makes a set dont they? Does anyone else?
Old Dec 7, 2000 | 04:41 AM
Mark 89Formula's Avatar
Yes, you do need the narrow body rockers with the centerbolt valve covers. Crane and Crower offer fully rollerized self aligning rockers. Comp Cams offers fully rollerized Pro Magnum and Magnum roller tip rockers that work.
[This message has been edited by Mark 89Formula (edited December 07, 2000).]
Old Dec 7, 2000 | 11:16 AM
Wraith's Avatar
I think you will need the self aligning narrow body rocker arm unless you have pushrod guide plates.
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Dec 7, 2000 | 12:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Self aligning rockers and guideplates dont mix. One or the other but you dont need both. I just bought GMPP roller rockers. Should work fine...
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Dec 7, 2000 | 02:43 PM
Hank Brote's Avatar
What heads do you have? That would help to answer the question concerning the rockers. I use Comp Cams Pro Magnums. They will fint under the stock covers with certain heads. An example of this is fitting under the covers with Edelbrock's without any grinding and not fitting under AFRs without grinding the webs.....
Hank
87'IROC Z28
Hanks 87 IROC
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
