If you're using 0W-Anything oil, you might want to read this...
Old Jan 9, 2002 | 07:57 PM
Vader's Avatar
I know I've seen several posts indicating that some members are using 0W-oils in their engines. While it's your engine and your choice, I thought you might be interested in this article:
Plain Bearing Lubrication
Pay particular attention to the Stribeck loading/speed curves for loading/RPM/viscosity thresholds. For an even lightly loaded bearing (like in a Toyota), their minimum recommendation is ISO 32 or 46. For those of you that don't remember, this equates to an SAE "made-up" viscosity number of 10W or 10, at a minimum. I know it's just an opinion, but they are lubrication professionals, and they only have science to support their opinion, not Dura-Lube infomercials. Too bad for them, eh?
In a related question, has anyone you know tried to retrofit the split roller bearings onto an SBC crank?
I'm thinking they could support some serious RPM with very low frictional losses. They would be heavy, though. It really wouldn't matter much on the crank journals, however.
Just checking.
Old Jan 10, 2002 | 01:28 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Good stuff. No idea on the roller bearings in a SBC here.....
Old Jan 10, 2002 | 01:40 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the info was informative.. but not solely applicable to zero
it could apply to almost anything that even used thicker oils. As zero anything goes.. I would only consider M1. The specs previously available (which might no longer be valid since mobil has changed hands and it is said that the manufacture of M1 has undergone cost cutting) for Zero-30 were better than the 5-30 version of mobil 1.
Old Jan 10, 2002 | 06:45 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
informative..
reminds me why oil coolers and the proper oil is a must on hi output engines..
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Thaney9
Aug 7, 2015 08:25 PM
