What do 1.6 rockers do anyway?
Old Jan 9, 2002 | 10:56 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I would think that they would increase the apparent lift of the cam, giving a relatively cheap alternative to a cam swap, without having to tear down the motor.
Are they a good mod for a 305 with a 'peanut' cam ??(4500rpm)
Old Jan 9, 2002 | 11:26 PM
craiger's Avatar
You hit it right on the button. They claim that you can gain from 10-20hp. I have a set for sale the crane Magnum roller tip 1.6 that only have 2500miles on them. I'm asking 125 plus shipping. I was going to use them on my new engine but the 1.6 rocker ratio and my new cam would create too much lift for the springs on my heads so I decided to sell them.
Old Jan 10, 2002 | 07:31 AM
82camaro's Avatar
Car: 82 camaro SC
You won't get as much power as a cam swap though. You need higher lift AND duration to make good power.
Old Jan 10, 2002 | 02:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I put 1.6 rockers on a relatively stock/mild 350. My times & speed changed exactly - zero.
82 has it right - it's a combo of lift and duration that has the greatest effect on power. There's a lot more to it than that, of course, but 1.5 vs 1.6 is not the same as a cam change.
Old Jan 10, 2002 | 04:20 PM
E-Z Rollin's Avatar
Lots of people think adding 1.6 rockers is an automatic hp increase,it's not. There's other factors involved like how much air a given head will flow at a given lift.
Old Jan 11, 2002 | 02:16 AM
SpeedCat86's Avatar
Okay, so I understand what lift and duration are in concept, but what does lift do versus duration?
Old Jan 11, 2002 | 11:51 AM
craiger's Avatar
It all has to do with when the valves open and close.. I'm sure someone could explain ti much better than me. When you choose a cam, you should match it to your intake, meaning if you have a tpi, you want a cam that will max out at aprox 5500rpms. YOu would not want to put a huge cam that made power up to 7000rpms because the tpi would choke at about 5500rpms. As far as the 1.6 rr, they will give you performance because they increase the lift, hence, more air flow. If you have very restrictive heads, then the gain will not be very noticible and gains from a cam would not be as dramatic either. If you are looking for more power, Heads are always the best spend cash. AFR''s are the best but most costly, Trickflow's, Edlebrock, etc... But the rolller rockers are the quickest and easiest to put on your car
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
