Changing the distributor in my '85 IROC to and '87+ style...What's needed?
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Hi, I'm changing the ditributor in my '85 IROC TPI (the HEI coil in cap design) to a '87 and up distributor, because it's smaller and uses an external coil (also the only distributor I can use in my new project). I see the wiring is different on these, can anyone give me any help as to how to make the new '87 distributor compatible with my '85's wiring harness?
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Old 1985 system:
http://www.geocities.com/vtcamaro/Pi...rams/pg152.jpg
New 1987 system:
http://members.home.net/millicanga/87tpi01.gif
You'll see the wire colors are the same, just change connectors.
New 1987 system:
mustangman65_79
Aug 11, 2015 03:17 PM
85, 87, diagram, difference, distrbutor, distributer, distributor, iroc, replace, replacement, replacing, tpi, wiring
