Spark Plug Wire Looms...
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Are the factory spark plug wire separators available new?...
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Spark Plug Wire Looms...
OEM GM ? Maybe from flea-bay But they are gonna be $pendy!
Aftermarket repops best deal on-line are the way to go.
Try this place: they had most of the clips I needed for a TPI 5.0 plug wire set.
https://www.mamotorworks.com/Corvett...tem-components
Is there a decent alternative to the stock ignition wire separators on the driverside with stock exhaust manifolds?
Mine are gone ( I think they got mangled when I tore engine down). I need to find some good OEM ones, or a good alternative. What are you guys using?...
GTA88
Dec 6, 2018 01:54 PM
