One Spark Plug Wire won't release from spark plug
Old Sep 2, 2018 | 12:28 PM
GTA88's Avatar
I have 30,000 miles on my plugs now, and I tried to take one out to check the gap and condition of the electrodes. I got a fairly good grip on it, in that confined space (it was on the passenger side, one of the 2 middle plugs), but couldn't get it to come off. I could have pulled harder, but I was afraid I'd break it.
I was able to get a plug wire off easily on the driver side.
What's the secret to getting a stuck wire off without ruining it?
Old Sep 2, 2018 | 06:00 PM
Re: One Spark Plug Wire won't release from spark plug
Twist it on the plug before pulling on it.
Then when you put it back on, put a bit of dielectric grease all around inside the boot.
Old Sep 2, 2018 | 06:08 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Old Sep 2, 2018 | 06:41 PM
I don't think that will help?? (but maybe)
Old Sep 2, 2018 | 09:01 PM
NoEmissions84TA's Avatar
Wiggle a small screwdriver in between the wire and boot.
Then get the straw from a can of silicone spray in there and give it a shot.
Twist the boot and it should be free.
And like Sofa said, dielectric grease to prevent this in the future.
Old Sep 7, 2018 | 05:12 PM
GTA88's Avatar
Thanks for the idea. I didn't realize the boot was separate from the wire. I'll give it a shot.
Old Sep 13, 2018 | 07:14 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Cool idea. Never tried that one. I have two different plug wire release tools that help quite a bit. One looks like screwdriver but with a hook at the end that fits around the porcelin of the plug and pushes the boot off as you pull. The other is a Thexton tool for GM 3.4s that sucks cause it's plastic crap, but does help sometimes. It catches the edge of the boot and helps pull it off. Between these two tools and twisting the boot, I manage to get them loose, usually without having to repair a wire afterward. I may try the silicone spray trick on the next stubborn one. Oh and +1 on the dielectric grease. I never do plugs without it.
Old Dec 6, 2018 | 01:54 PM
Larry's Avatar
Car: 86 Corvette
Deleted . I hate this new format.
Ozz1967
Sep 3, 2009 09:37 PM
TPIMarow6.6
Mar 14, 2005 01:54 AM
jfox55
Aug 13, 2002 03:46 PM
