Crossfire LU5 - Blocked Off water Passage?
Old Sep 29, 2019 | 09:50 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Does anyone know if any if the water passage ports are purposely blocked using a plate on the 305 Crossfire Injection LU5 motor?
I had to buy a corvette gasket kit for the specific crossfire intake manifold cover-to- intake manifold gasket, and this kit came with the rear ports blocked.
I already installed new intake manifold gaskets with no ports blocked, should I be worried?
Old Sep 29, 2019 | 12:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Crossfire LU5 - Blocked Off water Passage?
yes,rear ports are supposed to be blocked so coolant will flow through the channel under the intake and then to the heater core-not sure if any real ill effects will result with those ports open,
mgilorma
Jul 6, 2009 06:18 PM
jims85
Jan 25, 2007 07:18 PM
redbird_400
Sep 12, 2005 08:05 PM
1990GTA
Jun 3, 2005 03:02 PM
Keith5
Jun 25, 2002 09:47 PM
