Rough idle at cold start
Old Oct 14, 2019 | 06:48 PM
Jr Orozco's Avatar
I've been getting rough idling and almost stalling at cold startups for about a minute then it'll idle fine but i thought I'd check my fuel pressure and it went to the high 40s and immediately dropped. It slowed down once it was under 20 psi. Is that normal? Or is it supposed to hold? While idling it stays at 40 PSI. I have new fuel pump, fuel filter, injectors, fuel pressure regulator. 87 5.7 TPI. Thanks.
Old Oct 14, 2019 | 11:06 PM
Jr Orozco's Avatar
Re: Rough idle at cold start
Bump
Old Oct 15, 2019 | 12:05 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
As stated in the Facebook thread, the bleed down of the pump is normal.
Have you reset your idle, and IAC? Run through that procedure. Clean the IAC passage. Check to make sure the IAC isn't junked up thus not working right/sticky. If it looks rough, replace IAC.
Also, since you did all that work, check for vacuum leaks on the plenum/TB gaskets.
Pro
Dec 1, 2017 03:31 PM
Shane4524
Apr 25, 2012 07:28 PM
GTA
May 8, 2005 05:00 PM
kevinz85
Jun 6, 2004 11:41 AM
IROCThe5.7L
Jan 10, 2004 05:37 AM
