Help
Old Dec 19, 2019 | 02:11 PM
JT28's Avatar
Car: 1991 camaro z28
Help
Hey guys. I have a 91 z28 l98/700r4. My car won't start unless i prime the pump a million times for 5sec each time and on the last one i crank it for as short as possible and floor it until it starts. Sometimes it takes a few tries of this whole process and sometimes it starts right up without any priming or throttle input. When it does start it idles really bad (like a blower and huge cam, which sounds cool but thats about it) and dies when i put it in gear or give it gas. Or the idle will fluctuate up and down. And sometimes it just runs fine. What should i replace first?
Old Dec 19, 2019 | 02:30 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Help
If you simply load up the parts cannon and start replacing stuff with no diagnostics, you could wind up with more money in a still-not-running car than it's worth.
That said, the first thing to check would probably be fuel pressure at the fuel rail.
Old Dec 19, 2019 | 04:07 PM
JT28's Avatar
Re: Help
Thanks for the reply. I'll be back with an update soon
Old Dec 20, 2019 | 06:37 AM
Drew's Avatar
Re: Help
How many years has it been since the injectors and fuel pump were changed? I don't throw that out there as a recommendation to arbitrarily change them, but they're getting to be two things near the top of my preventive maintenance list. Both can have major impact on functionality, and are easier to deal with before they fail completely.
Old Dec 23, 2019 | 01:27 PM
JT28's Avatar
Re: Help
Ok guys so:
fuel pump and injectors could be the ones from the factory for all i know, although some of the passenger side ones have different color wires than the rest i noticed.
And as for fuel pressure:
0 with key off
45 with key on
35 when cranking
38 at idle
40 under load
Pressure begins to drop immediately after shutting the car off and reaches zero in like a minute
Old Dec 24, 2019 | 05:32 PM
Re: Help
If the pressure drops, either you have leaky injector(s), regulator, or fuel pump.
If it's the regulator, it will be leaking into the vac fitting. Unplug the line right after you turn the car off and see if fuel comes out.
If it's injectors, you can disconnect the main plug, take em all out as an assembly, let it prime, and see if any drip.
If it's not either of those, it's the pump.
Old Dec 24, 2019 | 06:12 PM
JT28's Avatar
Re: Help
Ok so. What's the main injector plug look like? And you mean take all the injectors out? Like pull the plenum and the runners and the rail and all that?
Carlos89
Sep 9, 2018 09:28 AM
mb2hurley
Jan 22, 2013 04:35 PM
