stainless valves
Old Jan 13, 2002 | 08:51 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
stainless valves
hello people.i'm doing a cam swap after allot of advice from you guys. ihave to change the springs so i'm thinking on removing the heads. my machinist says i should install stainless steel valves, they hold up to the abuse better. i'm also planning on nitrous, any experience withthis? would it be worth the money?
Old Jan 13, 2002 | 09:27 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the valves will see more heat
stainless will hold up much better. If you doing a valve job, I would not go back with the original valves and stainless are only about 90bucks a set.
You are less likely to pull a valve stem off with onepiece stainless.
If planning NOS go with at least 8 degrees more exhaust duration.
Old Jan 13, 2002 | 12:24 PM
craig's Avatar
Car: 86 camaro
valve job
ok i buy new valves , can i put them in my existing heads or do i need a new valve job to seat them?jcb my new cam has 15* more exhaust duration.
Old Jan 13, 2002 | 01:41 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
how long do have on the heads?
You really need to do a vj with new valves.. the seats won't match too well otherwise.. but.. if you don't have more than 10K miles on the existing topend.. I would not worry about it.
Old Jan 13, 2002 | 06:28 PM
craig's Avatar
Car: 86 camaro
i've got probably less than 2000 miles on the heads. i entered my specs wrong before it has .015 more lift and 8* more duration on the exhaust. how does your 400 run with the 4.10 gears? what rpm thru the lights?
sailtexas186548
Feb 17, 2017 03:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
m00n420
Sep 11, 2015 02:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
