1983 LU5 EGR valve; positive or negative??
Old Jan 26, 2020 | 04:27 PM
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
Should the EGR valve on an 83 LU5 305 Trans Am be a positive or a negative style? My GM FSM doesn’t specify. I have been battling a light throttle misfire and have tracked it down to the EGR valve. The one on the car is an aftermarket positive style. Vacuum is applied a few seconds off idle. With the EGR disconnected and the line capped, its smooth as can be. I have owned 15 thirdgen Trans Ams and have never seen a positive style EGR. I blocked it off and took it for a drive, and it runs beautifully, however an occasional ping can be heard.
1983LU5TA
Jan 26, 2020 04:57 PM
kallark
Aug 27, 2011 09:03 AM
92bird305tbi
Nov 2, 2003 09:44 PM
