1983 manual clutch T5 guys - What starters fit?
Old Feb 7, 2020 | 09:45 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok little background for those who don't know. 1983 was the only year of the T5 and the manual linkage z-bar clutch. Because of this, it uses a special bell housing used only for that year (P/N 14060627).
That's all well and good. But unfortunately the pocket for the starter nose on the bell housing is small and curved in so the LT1 starter doesn't fit.
I'm running a stock 1983 starter which weighs a ton and gets heat soaked from my headers.
Anyone with the 83 bell that has an aftermarket starter... what are you using?
Or, how did you modify the bellhousing to fit a regular any-other-year SBC starter?
Old Feb 7, 2020 | 12:20 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 1983 manual clutch T5 guys - What starters fit?
What about using a starter that doesn't have a nose/snout ? 1996 corvette starter.
Old Feb 7, 2020 | 01:44 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've never fit a starter into a Z-Bar bell-housing,... but:
I can't tell Ya' how many bell-housings I've seen with the starter notch cut-off in order to fit a big starter. Used to see it all the time when guys used an automatic starter after a stick conversion rather than buying the proper (smaller) manual starter.
aaron7
Jul 24, 2019 06:39 AM
camaro211z28
Jun 1, 2014 07:51 AM
utfan01ss
Jul 12, 2012 09:21 AM
online170
Jul 8, 2009 09:23 PM
xpndbl3
Feb 19, 2009 09:25 PM
