Vortec Stealth Ram Intake Gaskets Questions
Old Mar 12, 2020 | 07:27 PM
BHR's Avatar
BHR
using a vortec stealth ram intake went to test fit and see how bad the ports match the heads and noticed that theres alot of side to side play/movement against the heads this was dry without gaskets
went online to see if i can get another vortec base assuming mine was machined or altered only to find out that its discontinued unless i buy the cheap speedmaster brand while i was looking i noticed that the vortec intakes use different intake gaskets compared to the SBC in that there thicker so im assuming that the play that i have is b/c of vortec intakes using upwards of .60 thick intake gaskets
i noticed that theres only 2 design intake gaskets for the vortec intake the FP1255 and the gm plastic with the rubber rings the 1255 advertised as being thicker of the 2 at .120
my questions are
is it normal for the vortec stealth ram intake to head to have more movement side to side compered to the standard SBC?
are there other types of vortec intake gaskets other than the two i mentioned?
Old Mar 13, 2020 | 01:33 AM
GeneralDisorder's Avatar
Re: Vortec Stealth Ram Intake Gaskets Questions
They do use thick gaskets. And the factory plastic one's are a known failure point - often blowing out around the cooling ports. Get metal replacements. There are several from FelPro and Mahle, etc.
GD
greasegrenade
Dec 10, 2018 09:19 PM
patricklav
Nov 3, 2012 08:40 PM
Anomaly
Canadian Region
Aug 7, 2012 06:24 PM
Token
Feb 21, 2004 06:51 PM
Sauron91
Jan 19, 2002 09:19 PM
