T5 clutch pedal will only go down half way and won’t go into gear
Car: 1987 Camaro Iroc Z-28 Convertible
Engine: 355 Four Bolt Main
Hey guys I’m new here and never posted before but always referred to this site when trying to find answers on how to repair or upgrade.
I have a 1987 Camaro Iroc convertible and I recently swapped in a 350. When I did the 350 swap I also did the clutch, throwout bearing and slave cylinder.
I’ve been looking all over online and really need your help.
Previously when I shifted the clutch would go all the way to the floor. Now when I press the clutch it only goes half way down and the car won’t go into gear when running.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: T5 clutch pedal will only go down half way and won’t go into gear
Sounds like you might have installed the T/O bearing wrong. Do you remember how you mounted it ???
If you did you can get it corrected without pulling the entire tranny out. It ain't easy - but it can be done.
