86 trans am not runnin?
Old Apr 19, 2020 | 09:02 AM
@SeanBert's Avatar
Want a title? Post!
My trans am isn’t running but I’m not sure if it’s getting power to the fuel pump. Idk if it has an electric fuel pump in the tank because there is a mechanical fuel pump in the front. Also in the fuse box, there are empty spots where the fuses would be for the electric fuel pump, with no metal prices to hold the fuses in. Here is a picture of my fuse box
See there are no metal clips for the injection fuses, does that mean I just have a mechanical fuel pump?
Old Apr 19, 2020 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 trans am not runnin?
The pump fuse is net to the battery. Has this car sat for a long time or is this a new issue ?
tpi ? 2.8l computer controlled carb ?
if this is tpi you need injector bank fuses.
Old Apr 19, 2020 | 12:49 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
1986-87 carb engines are supposed to have a low power electric helper pump feeding the mechanical pump in order to reduce "vapor lock"tendency-this pump is turbine style with no check valve,will flow freely when not running.I do not know where this pump gets it's power or if it uses a separate fuse.Getting fuel to the carb?
DaScorpio96
Apr 16, 2020 02:29 PM
Chakadog
Carburetors
Nov 7, 2019 03:33 PM
Quick-IROCZ
May 25, 2006 11:40 PM
Tibey
Jul 22, 2003 05:12 PM
