Oil pressure sensor with male connector?
Old Jun 9, 2020 | 09:04 PM
xXasylumXx's Avatar
Car: 87' Iroc-z28
Engine: 350 TPI (L98)
Transmission: T-5 Non W/C
Hello, my oil pressure sensor behind the distributor seems to have a male connector, I’m trying to buy a new sensor but everyone I see needs a female connector,
is it possible the old piece off the sensor is stuck in the connector? I tried pulling it out but it wouldn’t budge, don’t wanna break it.
also any idea what that other connector goes to?
Old Jun 9, 2020 | 09:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Oil pressure sensor with male connector?
Top picture is the sender for the oil pressure gauge or idiot light. Use to have a spade male connector.
look at the female end for broken piece. The 2 prong is ops ps135 standard motor products.
Old Jun 9, 2020 | 09:25 PM
xXasylumXx's Avatar
Car: 87' Iroc-z28
so the male connector is normal? I don’t see anything broken. Also did these cars come with the wiring for that but not use it? Cause that 2 prong one was never hooked up.
thanks again your always a big help.
Old Jun 9, 2020 | 09:39 PM
Engine: Lb9
Transmission: M20
Not having the 2 prong one hooked up will cause harder starts.
there are 2 ops gauge senders one for 60 psi max gauge and one for 80.
Old Jun 10, 2020 | 08:42 AM
xXasylumXx's Avatar
Car: 87' Iroc-z28
thank you
Black88Z
Nov 5, 2012 07:10 PM
Birdstheword
Aug 2, 2010 08:44 PM
89V6FBIRD
Oct 27, 2002 04:03 AM
