86 Z28 5sp LG4 fuel line replacement ?
Old Jun 25, 2020 | 11:00 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Has anyone here ever replaced the fuel lines on a carbureted Camaro. Tank to motor. It’s been sitting for about 20 years and one line was leaking so I want to replace them. The car runs but not good. Thanks for your time.
Old Jun 28, 2020 | 09:56 AM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Engine: L31 Build in Progress
Transmission: NWC T5 till it blows
Re: 86 Z28 5sp LG4 fuel line replacement ?
i am sure someone has. without too much consideration the options are order a new one or make your own. i imagine dropping the tank would be the hardest part (if you go back that far) i have a 86 ta lg4 5sp so ive been under mine. that was the hardest looking part to me.
Old Jun 28, 2020 | 10:28 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
no need to drop the tank. the steel lines from the tank are connected to the body lines with short sections of fuel hose. there is a mounting point directly over the transmission that may pose a problem if you install them with the transmission still installed, might be able to do it with the tranny dropped some and the driveshaft/TQ arm removed.
look underneath and the routing is fairly straightforward.
Old Jun 28, 2020 | 11:50 AM
Z03Z28's Avatar
Thanks guys in going to go it a shot next weekend.
86B4Z
Feb 18, 2014 06:09 PM
worldman100
May 30, 2011 02:04 AM
3rdgenrookie
Carburetors
Oct 18, 2007 12:49 AM
