350 5.7 L SGI 1988 6 to 1988 14088548. need help trying to figure out how much hors
Old Aug 20, 2020 | 11:33 AM
Mikejackson 75's Avatar
Car: 2011 MALIBU , 95 SILVERADO
Engine: 1986 TO 88 350 5.7 L SGI 4 BOLT MAI
I've been searching the internet and everything somebody out there please help 350 5.7 L 1986 to 1988 4 bolt main V0308 UPJ. Need no the horsepower ratio everything. thanks
Old Aug 20, 2020 | 12:05 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 350 5.7 L SGI 1988 6 to 1988 14088548. need help trying to figure out how much
There are all the years of tech data at the top of the page, this is for 88
https://www.thirdgen.org/1988-pontiac-firebird/
Old Aug 20, 2020 | 01:00 PM
Re: 350 5.7 L SGI 1986 to 1988 14088548. need help trying to figure out how much
The only difference I could find from mine then from the Corvette and Camaro is that year is they had to Roller cams with the spider thing up underneath the intake mind you got it to where it could be drilled out for it same blocking everything I need to find the horsepower so I can get me a cam for it someone told me that they think it's got like 200 to 300 hp like that stock. came out a 1 ton
Old Aug 20, 2020 | 01:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you can’t identify the engine off the suffix see the head casting number.
if it’s a 4 bolt main probably from a truck with junk heads.
Old Aug 20, 2020 | 02:05 PM
Yup, assuming the 88 motor is still intact such that the stamping code means anything at all, probably a SIGNIFICANT downgrade. Although in 86, AFAIK the only chassis that a 350 came in anyway, was trucks; so that's not gonna be much of a rompin stompin bit-chompin monster either.
All of these comments assuming of course, that the motors in question are never-opened, COMLETELY INTACT virgin untouched engines. Not efffffing likely for abuncha ANTIQUE car parts. Your best bet is to ignore the "codes" and LOOK AT THE ACTUAL PARTS.
BEETEROLDS
Feb 3, 2013 11:48 AM
autouzi
Aug 24, 2009 07:02 AM
camaro1185
Jun 12, 2009 10:46 AM
NORTHSLIDER
Members Camaros
Apr 8, 2008 11:00 PM
