Correct Power Steering Pump
Old Sep 8, 2020 | 09:28 AM
Angelduran5858's Avatar
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
I have been having an issues trying to locate the correct power steering pump for my 1987 camaro 305 TPI V Band setup i have ordered several different and every time have shipped me the same part I am wondering if anyone has info on the correct pump I need for my set up thank you
Old Sep 8, 2020 | 09:45 AM
Drew's Avatar
Re: Correct Power Steering Pump
Some of the parts catalogs think 87 was the first year for the serpentine belt system. You might try ordering one for an 86.
Really, it's only the reservoir that's different. If you want it done now, just remove the bolts/studs/fittings from the back of the reservoir, clean the crud off the old reservoir, and pop it on the new pump.
Old Sep 8, 2020 | 03:57 PM
Just be sure when you do that, to avoid distorting the reservoir... it's just this real thin sheet metal, and it seals to the pump itself with a large O-ring, and if the reservoir isn't straight, it'll leak severely. Unfortunately it looks like somebody might have already beat you to it though.
pontiacdog
Mar 15, 2014 07:51 AM
stangStomper83
Aug 9, 2004 05:15 AM
ChevyGuy87
Nov 11, 2001 09:02 AM
