How accurate does the CTS need to be?
Old Oct 19, 2020 | 12:17 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I have noticed a cold long crank the last few weeks and wondered if it might be CTS related, so I checked it with the DVOM and it read 2.890K at 65 degree ambient temperature. Chart shows that it should be about 1K higher resistance at that temperature. Last data log I did (on Sunday) showed 85 degree CTS reading at start-up with ambient of ~65 degrees, so about 20 degrees off. Is this enough to cause a problem? The CTS was replaced when I did my original TPI conversion a few years ago and then transferred to the L31 about 10 months ago (about 3,000 miles total). Complete disclosure: also replaced the ICM a few weeks ago (AC/Delco D1943A).
Old Oct 19, 2020 | 12:20 PM
GeneralDisorder's Avatar
Re: How accurate does the CTS need to be?
Yes. Replace it.
GD
Old Oct 19, 2020 | 09:46 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks, ordered a new sensor. Just didn't want to have to swap it out unless really necessary.
2mnytys
Jul 30, 2017 07:38 AM
usacamaro
May 30, 2010 10:17 PM
TPIMonteLS
Oct 24, 2009 12:16 PM
kaupca
Oct 28, 2003 06:53 PM
9D1BURD
Jun 19, 2001 03:55 PM
