High warm up idle during cold start is nonexistent
Old Nov 26, 2020 | 11:20 PM
JakeSegovia's Avatar
So, I recently changed the pickup coil in my 89 trans am gta 5.7, but now when I cold start, the typical high idle at around 1500rpm doesn't happen anymore. Now I have to hold the throttle to keep it alive and warm it up or it will stall out. And now once it warms up, it idles at around 550-600rpm in drive and park/neutral. Also on top of that, the vacuum hose from my cruise control disconnected from wherever it came from (I think from the intake manifold). But i want to be sure. Any ideas?
Old Nov 27, 2020 | 12:11 AM
ULTM8Z's Avatar
Re: High warm up idle during cold start is nonexistent
I suspect you removed the distributor to change the pickup coil. Are you certain the ignition timing was set properly upon re-installation?
The stock idle speed programmed into the ECM is 575 rpm at full warmup, so that idle speed is correct for a fully warmed up engine.
Maybe start with the basics... reset your idle speed...
https://www.thirdgen.org/tpimod2/
Old Nov 27, 2020 | 07:14 AM
Yes. I set it back to 6 degrees BTC. I’ll try what was posted in the link
Old Nov 27, 2020 | 11:41 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
If you have a disconnected vacuum hose you probably have a vacuum leak. Fix that first, then reassess your other issues (if they remain).
Old Nov 27, 2020 | 04:53 PM
So I connected my cruise control back together and it works fine. But now it’s still 50/50. Sometimes it will start with the high idle and other times it will not.
Old Nov 27, 2020 | 05:53 PM
ULTM8Z's Avatar
Did you do the idle adjustment procedure?
Old Nov 27, 2020 | 07:54 PM
I adjusted the t-20 screw on the idle adjustment for the butterfly valve enough to where it idles normal. Its still 50/50 but now I noticed fuel injector for cylinder 7 started leaking fuel. So now that could be a factor as well. I believe its either the O-ring or its not seated right.
Jon87Z28
Carburetors
Feb 22, 2023 02:31 AM
British Rich
Nov 28, 2007 12:06 PM
flowmasterchevy
Oct 30, 2004 10:56 PM
25THRSS
Oct 15, 2003 06:46 AM
