Rebuilt tpi 350 swap first start ,runs but won't stay at idle dies?
Old Nov 28, 2020 | 07:33 PM
88irocz91rally's Avatar
Car: 1988iroc z and 1991 Camaro Rs
Transmission: 4 speed and 5 speex
1991 Camaro RS 350 tpi 6 speed is from a 1988 Camaro . Harness was converted to work with a speed density computer 7730 was originally a 305 tbi 5 speed computer and harness. Egr delete and 9th injector delete. The engine fires up and stays running if I keep my foot slightly on the pedal seems to sound ok but it doesn't want to idle soon as I let off pedal it dies . Anyone have any ideas what I should check I've been reading about resetting the IAC , the motor ran fine when it was in the maf 88 before I decided to pull it , appreciate any thoughts and suggestions.
Old Nov 28, 2020 | 07:40 PM
ULTM8Z's Avatar
Re: Rebuilt tpi 350 swap first start ,runs but won't stay at idle dies?
Did you run through the minimum idle setting procedure in the how-to's section?
Old Nov 29, 2020 | 07:18 AM
Not quite yet I was reading up on that though , I will give that a try thanks
64gtoguy
Aug 26, 2010 03:57 PM
lotsofsparepart
Nov 25, 2008 07:39 AM
subroc
Sep 26, 2005 02:32 AM
TKD89RS
Feb 1, 2003 11:56 PM
