wierd idle when started
Old Sep 19, 2005 | 04:18 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
hey everyone. Until yesterday i just shrugged this off as usual for an old TPI car but now im not so sure. When i start the car up it start and idles at about 500rpms in park then it goes up to 1500rpms then drops down to 1000 and stays there for the most part. Isn't it supposed to just start and go to 1000? Is my IAC valve faulty? I bought it not long ago but its a NAPA unit and i used to work at napa so i know all the horror stories about electronics. Also could it be related to my 9th injector? It doesn't run too smooth when its cold. The idle likes to bounce around for awhile until it warms up.
Old Sep 19, 2005 | 10:09 PM
subroc's Avatar
Engine: 355 TPI
bump
Old Sep 21, 2005 | 09:57 AM
subroc's Avatar
Engine: 355 TPI
come on...no ones got an answer for this one?
Old Sep 25, 2005 | 11:01 PM
tagta189's Avatar
Actually these things are supposed to go to 1500 rpms at start up then slowly nudge their way back down to the idle speed over a period of time,and even when fully warmed up it will still take at least a few minutes to get back down to the final idle speed.As for why it idles at 500 to start,mine wants to do that too but you have to give the computer time to nudge that iac upwards.
Old Sep 25, 2005 | 11:41 PM
subroc's Avatar
Engine: 355 TPI
Oh ok thanks. I didn't know if this was the way it was supposed to act or not. Ive seen a few that just start up and idle at 1000 right off the bat. but i guess every TPI car is different.
Old Sep 26, 2005 | 02:32 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well, if u have any doubts or worries read the setting TPS and IAC article on this site.
Runs you thru it step by step and make sure u start out with a clean throttle body.
later
Jeremy
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
