Steering Wheel Shaking all to hell
Old Jan 15, 2002 | 10:03 PM
rhyners's Avatar
Im having a problem occasionally when I hit the brakes in my car. The steering wheel shakes bad. I checked my rotors and they were warped so I replaced them thinking that would fix the problem. It turns out that the rotors became warped because of the problem. If anyone has any ideas I would appreciate it.
Old Jan 16, 2002 | 12:38 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I must admit, I'm a little "Confuzed" with your question....
OK...so the problem is???
Seriously though, I think I would check the brake calipers first. Sometimes the seals stick and they lock up, usually holding the pads tightly to the rotor and overheating, then warping the rotor.
On the car I have, I bought it after sitting dead in a driveway for 4 years, and apparently, when the car sits idle for that long, brake fluid becomes "contaminated" with water and the rubber hoses going to the caliper swell internally and lock the pressure in the caliper. I would have never guessed it myself in a gadzillion years.....but someone on this board had "been there - done that" and that's what it turned out to be. That's why I like this board.
Take it to Car-x or Midas and get a free, or almost free estimate if you're unsure what the problem is. Hey! It's never a bad idea to get the opinoin from someone that does this stuff everyday!
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
