Missing at Idle only
Old Dec 29, 2020 | 08:32 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
My TPI engine has a miss fire at idle it seem. All wires have spark and fresh plugs. The issue is only at idle though, it will cruise perfectly without any surging or anything. With the WUD hooked up on my laptop I can see the timing dropping from 26 to 18 at idle and kPA going from 57 to 48. Could this be a misfire caused by induced current in the spark plug wires due to bad wiring near the coil?
Old Dec 29, 2020 | 08:43 PM
msammy93's Avatar
Engine: 383 TPI
Re: Missing at Idle only
Well, messing around with it outside now and just noticed that when I move the ignition coil wiring (4 wires) the car wants to stall out. I actually just tucked the wiring behind the coil (moved it closer to firewall) and the engine stalled and would not start back until I put it back where it was. It would crank but not fire. The wiring does not seem to be damaged or broken anywhere so confused. Guessing bad ignition coil causing the miss fire? Or is there a module or anything that I should be looking for? My first time dealing with an engine that wasn't and HEI. Not sure how this whole separate coil system works.
Old Dec 30, 2020 | 01:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is a common problem that the pigtail that goes between the remote ignition coil and distributor ICM breaks inside of the insulation. It is usually at the coil end where the wires enter the hard connector. The wire breaks at that point but the insulation holds it together.
RBob.
Old Jan 4, 2021 | 03:13 PM
msammy93's Avatar
Engine: 383 TPI
RBob.
Thanks for the reply. Will be sourcing a new pigtail.
zeitghaist
Apr 28, 2015 03:40 AM
87tpi7749
Mar 20, 2007 01:37 PM
trlprk
Oct 18, 2006 08:32 PM
dimented24x7
Apr 10, 2005 10:09 PM
PLANT PROTECTION
May 10, 2003 01:10 AM
