engine miss at idle
Old Oct 16, 2006 | 09:39 PM
trlprk's Avatar
engine miss at idle
Hey guys, I just bought an 87 Iroc with a rebuilt 350, and it was converted to a t-5 , the engine runs very well but I am getting a mis fire at idle and at a light cruise. where should I look to first? thanks in advance.
Old Oct 17, 2006 | 04:28 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
If the car is still running the computer checking for codes would be a good starting place. Other than that I would look at the plugs and plug wires.
Old Oct 18, 2006 | 08:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
As above, first check for error codes, idle car in the dark & look for shorts, check all ignition wiring, pull plugs & inspect, check timing at idle.
eightsixseven
Dec 16, 2024 01:50 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
