Sbc 355 rebuild
Car: 74 chevy z28 81 chevy c10 66 oldsmo
Engine: 350 bored 30 over
Transmission: 400 turbo
Sbc 355 rebuild
looking for advice on building a sbc 355 the block in a goodwrench 350 crate 2 piece rear seal engine that has been bored 30 over the pistons are flat top 4 relief speedpro 345np it has a standard 3932442 crankshaft and stock vortec heads 062 looking for a good camshaft for the street trans is a stock 400 turbo and stock gears in the rearend, motor will be going into a 81 chevy c10. any advice would be greatful thanks.
Re: Sbc 355 rebuild
Sounds like a pretty normal build to me. Should run decent if all the supporting parts are there. Depending of course to some extent on which "stock" gears you have. Let's hope they're at least 3.73.
I think I'd slide a Comp XE262 w/ 1.6 roller rockers in there. LS6 springs w/ 787 retainers, set em up to between 1.75 & 1.80". I'd also put whatever converter in it that would stall at about the RPM where the truck is doing about 40 - 45 in 3rd gear.
This is a forum for 82-92 Camaro & Firebird exclusively. Not a general tech or engine Q&A. Yeah I know there's a fair amount of knowledge around here about the older SBCs, and lots of people like to come on here and when this is brought up to them give us the "but... but... but..." and call the people who are offended abuncha a-holes, but still, the operative concept is and remains, EXCLUSIVELY. You might have good luck for further help on performancetrucks.net for example.
