Starter motor
Old Feb 1, 2021 | 11:50 AM
BRYDENGTA's Avatar
Car: ProCharged 1988 Trans Am GTA
Engine: 383 stroker with TPiS miniram
Transmission: fully built 700R4
Axle/Gears: late model 4th gen axle
Starter motor
Hi all I am trying to find a starter motor to go on to my 383 stroker build.
Currently I have a LT1 starter on my L98 as it is the only starter I could find that was smaller enough and would fit with the Stainless Works long tube headers but now I have built a new engine
which is a Dart block and has a 168 tooth flexplate so need a 168 tooth style Starter motor that would fit with the Stainless Works headers.
Can anyone recommend a small LT1 style 168 tooth starter
Any help would be greatly appreciated
Old Feb 2, 2021 | 06:59 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Re: Starter motor
There are two types, an F-car/B-Body and a Corvette, use the Corvette style LT1 starter. Its even smaller than the Fcar/B-Body starter and comparable to any mini starter in size. I use one on my LT1, 1-7/8" headers on that car so space is key
Old Feb 2, 2021 | 07:02 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Starter motor
90's truck starter motor. try a 96-99 vortec or maybe even an LO5 starter motor. I've used them, but not with your headers. can't remember the specific years. just check the box and try the fitment.
It'll have the staggered bolt pattern but otherwise be similar to the LT1 style.
Old Feb 2, 2021 | 11:46 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Starter motor
Chevrolet Performance high torque mini starter would be an option. It works for both 153 and 168 tooth flywheels. It's pricey though.
Old Feb 2, 2021 | 01:47 PM
Re: Starter motor
There are any number of the "mini starters" that work w/ both bolt patterns.
Most of them look like the Delco one; they're made by Hitachi. (or I should say, are "based on") Others look like the one for Vettes; those are Nippondenso style.
Alternatively you could put a 12.8" flywheel on it. That's probably what I'd do if I had header fitment worries.
Old Feb 5, 2021 | 08:30 AM
BRYDENGTA's Avatar
Re: Starter motor
I am thinking about changing to a 153 tooth flexplate as that would cure my problems better
Old Feb 5, 2021 | 10:21 AM
naf's Avatar
naf
Re: Starter motor
good idea. then consider the LT1 style starter. if picked up from the local parts store, it can be returned if fitment is not 'good'
Out-Cast
May 5, 2017 06:33 PM
Chuck
Aftermarket Product Review
Aug 24, 2016 12:39 AM
4RCEPWRD
Jun 10, 2008 11:46 PM
gapimpin
Apr 21, 2008 11:50 PM
bubbz89
Oct 9, 2004 07:31 PM
