starter probs
Car: 1990 RS
Transmission: TH-350
starter probs
i am installing my hedman longtubes and the starter isnt letting it happen. it has the staggered bolt pattern and i was wondering if someone could point me the right way to finding a smaller starter. all the ones i see are for straight bolt patterns. tia
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The aftermarket starters, such as the one from CVR (I have this one) has holes to allow for multiple starter angles and can fit either flexplate/flywheel tooth.
What starter are you using? Last I checked, long tubes won't clear the factory coffee can motors.
Gunner242
Dec 25, 2015 04:49 PM
You could probably ask to see one at your local NAPA and get a visual.
