does this sound like a leaky intake?
Old Jan 16, 2002 | 11:20 AM
TBI305Camaro's Avatar
my car leaks oil while running and just after it is turned off..after about 5 nin it stopps when the car is off...its coming from the back of the car somewhere onto the tranny...think its the back of the intake manifold?
Old Jan 16, 2002 | 11:38 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It could be an intake leak if the intake has the cheapo plastic center gaskets or it could be a valve cover gasket leak. The only was to know for sure is to squeeze your hand back there and feel around which is almost impossible or jack the car up and take a look.
SSC
Old Jan 16, 2002 | 07:47 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
It could be the distributor gasket. There is a little round gasket that seals the distributor to the intake. I have had that leak in a car of mine, and it did exactly what yours is doing.
Mike
Old Jan 17, 2002 | 07:05 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I've been dealing with the same type of problem.
I'm almost certain its not the back of the mainfold since I've re-sealed it and checked with hand and mirror several times and found no oil residue whatsoever.
Definitely check the gasket between the distributor and manifold. I had one there but it still leaked. A bit of RTV fixed it up.
Also make sure your valve cover gaskets are good. Tighten down the valve cover bolts a notch. Check/seal/or replace the grommet where your PCV valve goes. Also make sure your oil filter is on tight (I was taught hand-tight, but I give it an extra twist to be sure).
After doing all of this the leak is now alot less but I sometimes still get a few drops when I turn the engine off. It seems to be leaking right at the back of the engine on the drivers side, where the oil filter goes.
I'm being lazy now, but soon I'll put it on a lift so I can get right underneath it to eyeball the leak.
Old Jan 18, 2002 | 09:18 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I bet it's your oil sending switch.
It's located on back of the intake on the driver's side of the distributor. Usually has a small pipe that screws into the intake.
When it leaks, it runs down the back of the engine as well as the top of the tranny. Check it out.
Old Jan 19, 2002 | 01:33 PM
there isnt any oil from around the valve covers and i just replaced them anyways...how hard is it to change the distributor gasket? and i have removed the oil sending unit...there is oil back there around the distributer not sure exactly were its from tho
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
DJanes97
Sep 1, 2015 02:55 PM
Catcher55
Aug 15, 2015 07:08 PM
mustangman65_79
Aug 8, 2015 12:07 PM
