will my compression change?
Old Jan 16, 2002 | 12:31 PM
82sportcoupe's Avatar
i might be beating this to death but, my 8.5:1 compression 350 is getting a new set of heads. the current heads are junk. 72cc. vortec was an option, now im leaning towards the sportsman II's because i dont have to change as much and they flow a little better. if i were to get the 64cc sportsman2's, would the head change increase my compression to a little higher number if i use the same gasket thickness's/ whatever? if someone has it, i would like an old style formula to calculate this. just to have. anyways, I just want to know if i would bump up the compression to a little healthier of a number. if noone feels like giving me formulas or numbers. a simple yes or no answer would do just fine. will it increase my compression with these heads? 72cc or 64cc? y/n? im not too good with heads so any help for this would be appreciated.
Old Jan 16, 2002 | 12:44 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Yes it will go up everything else remaining the same. How much? I am not really sure, but I am sure it will be close to 9:1. Smebody who knows math will probaly be more exact, but it will go up.
Mark
Old Jan 16, 2002 | 12:45 PM
woo hoo, thank you!!!! it will go up..... but for the tricky part, how much?
Old Jan 16, 2002 | 12:55 PM
rezinn's Avatar
If your current heads are 72ccs changing to 64 will give you about 9.4:1
Old Jan 16, 2002 | 01:05 PM
thanks a bunch guys, i would be lost without all of your help.
Old Jan 16, 2002 | 02:09 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i found a cool site that has tons of math formulas and does the calculations for you. Check it out
www.smokemup.com
customblackbird
Aug 15, 2021 10:16 PM
gixxer92
Sep 1, 2015 04:32 PM
Thornburg
Aug 25, 2015 01:46 AM
86IROC112
Aug 21, 2015 07:20 PM
