engine surges every 2 seconds with AC on?
Old Mar 26, 2021 | 03:47 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
For some reason, when my AC on, my RPM's will shoot to 900 then drop to 600 rhythmically every 2 seconds. Is this a tuning problem? Happens only at idle, when I am cruising RPM's are smooth as butter.
Old Mar 26, 2021 | 06:57 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: engine surges every 2 seconds with AC on?
When the RPMs rise and fall do you hear the A/C compressor cycling? If you hear a prominent click sound every time the RPM drops it likely is your compressor cycling that's causing the RPM fluctuation. Two seconds between cycles usually means that the refrigerant is somewhat low.....
Old Mar 26, 2021 | 07:32 PM
msammy93's Avatar
Engine: 383 TPI
I Checked for that earlier and the compressor is staying on the entire time. I thought that was the problem at first too but seems like something else is causing it which is weird. Nothing related to the fan either because with the fan on and ac off the idle is smooth
Old Mar 26, 2021 | 08:40 PM
GeneralDisorder's Avatar
Adjust your base idle air and ensure the IAC is around 10-15 steps.
GD
Old Mar 26, 2021 | 08:42 PM
msammy93's Avatar
Engine: 383 TPI
GD
Does having IAC too high cause that? Right now it's at 22-24 at warm idle.
Old Mar 27, 2021 | 10:22 AM
It's not what the computer is expecting, so..... possibly. Close the throttle stop and get the steps in the correct range. Might help, might not. Easy fix.
GD
Old Mar 27, 2021 | 04:51 PM
msammy93's Avatar
Engine: 383 TPI
I think I have fixed the issue. Will drive it again after later to see if it is fixed, but set my IAC A/C Delta steps to 0 for both the min and max and took it for a ride around the block and did not noticed the surging. So it was IAC related, but I still have no idea why.
RSTealer
Feb 25, 2015 10:10 PM
IROCThe5.7L
Jun 22, 2009 11:57 PM
Jassack
Dec 5, 2007 07:37 AM
dsaint1347
Nov 1, 2003 08:54 PM
Hummer
Jun 25, 2001 05:09 PM
