What is this piece called? For an 87 firebird
Old Apr 13, 2021 | 12:12 PM
Briantokay's Avatar
I cannot find it anywhere online
Old Apr 13, 2021 | 01:42 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Re: What is this piece called? For an 87 firebird
I stand corrected, see the more accurate post from Reddragon88gta
Old Apr 13, 2021 | 01:53 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
https://www.gmpartsdirect.com/v-1987...ine--air-inlet
It says its called an "adapter", if you need one I would call a third gen specific salvage yard/used parts place or ask around on here in the parts wanted. There are a few members who have a lot of used factory parts for sale, try firebirddude142 he seems to have a lot of stuff.
Old Apr 13, 2021 | 02:17 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If you aren't stuck on original parts, look for 88-89 air filter housing, 2 rubber bellows and the MAF sensor bracket.
May also have to change the plastic upper radiator support bracket to the 88-92 part make the factory maf bracket fit.
Much better setup
Jokersall
Jun 7, 2016 07:46 PM
Jim98TA
Nov 23, 2009 09:19 PM
