FUEL TANK
Old Apr 29, 2021 | 12:34 PM
tu88formula's Avatar
FUEL TANK
I HAVE A 88 PONTIAC FIREBIRD FORMULA 305 TBI I HAVE BEEN HAVING ISSUES WHEN I PUT FUEL INTO THE FUEL TANK IT SPITS IT RIGHT OUT AFTER I POUR IT IN....I DID REPLACE THE FILTER ON THE FUEL LINE AND IT DRAINED OUT 9 GALS OF GAS BEFORE IT STOPPED POURING OUT...WHAT COULD BE CAUSING THIS ISSUE...
Old May 1, 2021 | 12:21 PM
Vader's Avatar
Re: FUEL TANK
Is the fuel spewing back out the filler neck, or somewhere else from the tank?
Old May 1, 2021 | 03:28 PM
Re: FUEL TANK
out of the filler cap...
Old May 1, 2021 | 07:40 PM
Vader's Avatar
Re: FUEL TANK
The EVAP lines, purge valve, and connection of the filler neck should be checked. It seems that something is trappiing air in the tank while it is being filled.
Old May 3, 2021 | 07:36 AM
Re: FUEL TANK
i will check that,
thanks for the info...
IROZINCO
Jan 7, 2014 09:16 PM
little8camarors
Jun 30, 2010 09:49 PM
blackbeauty
Aug 17, 2007 05:11 AM
super_kev
Jun 27, 2006 12:12 AM
Liquid_Metal
Mar 23, 2006 10:56 AM
