Engine will not turn over
Old May 27, 2021 | 01:23 PM
HeathGuy's Avatar
Car: 89 Firebird Formula
Transmission: Automatic
Hello, I'm new here and I recently bought an 89 Firebird Formula. Here's a little back story to my problem. I recently bought the car and I started changing the fluids in it. I'm currently doing a coolant flush and I went for a drive after putting new coolant in. The engine eventually got hot so I shut off the car. Turns out my dumbass forgot to put the radiator cap back on so I literally jogged home to get some more coolant. When I got back I filled her up and drove it back home without any problems. The next day I go to start her up and she will not even turn over. The electronics come on but no attempt to even turn over. Did running it hot mess it up somewhere?
Old May 27, 2021 | 02:58 PM
Yeesh's Avatar
Re: Engine will not turn over
Try it now.
Do you hear any clicking or other noises when you turn the key? Battery voltage?
Old May 27, 2021 | 03:02 PM
HeathGuy's Avatar
Originally Posted by Yeesh
Try it now.
There is power, but when I turn the key nothing happens not even a click. Im starting to wonder if it's a problem with the vats.
Old May 28, 2021 | 06:45 AM
Yeesh's Avatar
What is the security light doing?
Old May 28, 2021 | 08:25 AM
HeathGuy's Avatar
The security light doesn't come on if that's what you mean.
Old Jun 1, 2021 | 02:00 PM
HeathGuy's Avatar
It was vats. I bypassed it with a wire that has the same resistance as my key.
HeathGuy
May 27, 2021 01:21 PM
waraney
May 23, 2019 11:48 AM
1989RS_Camaro*
Nov 20, 2011 07:29 PM
The_Phoenix
Sep 9, 2007 11:41 PM
tommyboy51300
May 23, 2005 10:26 PM
