Engine Updates
Old Jun 2, 2021 | 09:09 AM
Chad Speier's Avatar
Car: 1986 IROC
Engine Updates
Hey guys, thought I'd give you a little update. I have 600 miles on the engine build. I updated a few things. I put a set of DW 48lb injectors and a GZ vacuum pump. I have the vacuum pump set at 8" of vacuum. What a difference it made! After all it's a 1/1/2mm ring package in a stock block! lol.. I will post a few videos. They don't come close to being in the car. It's a beast for NA. Small, high flowing, proper high velocity, makes it a acceleration beast!
Video of rolling at 1000 rpm, notice how fast it finds 6000+
Video of rolling in OD and notice how fast the car accelerates!
Old Jun 2, 2021 | 11:26 AM
skinny z's Avatar
Re: Engine Updates
That engine of yours is one of my personal favourites. Nicely done.
As strong as it sounds, any idea on what your cruising MPG might be. Of course that means not sticking your foot in it for a tank of fuel but it would be interesting to know. Case in point is the "fleet" Chevelle. It's a 10.9x car with an LSX 454 and a real cruiser not a drag racer. 20+ (USG) highway mileage so it's not a slouch there either.
Again, well done.
Old Jun 2, 2021 | 10:43 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Engine Updates
How do you like the GZ vac pump? Have you tried other brands?
Old Jun 3, 2021 | 07:47 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Engine Updates
Time for a track day
Old Jun 3, 2021 | 11:03 AM
Car: 1986 IROC
Re: Engine Updates
I like it. I've used them all. Starr is the best, IMO. I liked this because I was trying to use some of the OEM brackets, and I did.
Old Jun 3, 2021 | 11:04 AM
Car: 1986 IROC
Re: Engine Updates
Again, well done.
Thank You! I need to check MPG. I think it would be decent.
Chad Speier
Alternative Port EFI Intakes
Aug 10, 2021 03:41 AM
Sn0wm4n
Carburetors
May 5, 2020 03:07 PM
red rock
Jul 30, 2016 10:19 AM
manolis1969
Mar 16, 2013 07:20 PM
Cornholio7979
Carburetors
22
Aug 1, 2007 03:53 PM
