mass airflow sensor
Old Jan 16, 2002 | 10:27 PM
89_RS_Mike's Avatar
mass airflow sensor
What is the outside diameter of the opening on V8 mass air flow sensors?
Old Jan 17, 2002 | 01:24 AM
Guest
Guest
Posts: n/a
How exact of a measurement do you want? IIRC its 2 7/8" A 3" ID tube works great for a cold air inlet, in case thats what you are up to.
Old Jan 17, 2002 | 01:40 AM
89_RS_Mike's Avatar
Thats exatly what im up to thanks
Old Jan 17, 2002 | 01:55 AM
Guest
Guest
Posts: n/a
I'm currently using.. I think its ABS plastic tubing. Its pretty thick stuff unfortunately, had a hard time finding a clamp. I had to use part of a rubber ring that comes on the early TA air inlet setup to take up some space. At first I had used some stuff that is for landscaping/drainage, I think its polyethelene, its black with what appeared to be a white plastic coating on the outside. Over time it melted slightly and deformed, and was not sealing properly anymore. Thats why I went with the thicker stuff, it has not given me any problems.
Having an exhaust pipe or even stainless bent or hopefully just cut to size would work too, probably look better but heavier.
Old Jan 17, 2002 | 04:18 AM
89_RS_Mike's Avatar
I plan on using exhaust pipe and having it mandrel bent. If there is exhaust pipe that is 3" ID.
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
